Batch rename the search results
marsh
Post by marsh »
I use Xnview's search to find media files with <space> character (something MS search cannot do, I think) and then use batch rename to replace <space> with <underscore> in many seperate folders. If batch rename could be performed on search results, then it would be more versatile.
Re: Batch rename the search results
marsh wrote:I use Xnview's search to find media files with <space> character (something MS search cannot do, I think) and then use batch rename to replace <space> with <underscore> in many seperate folders. If batch rename could be performed on search results, then it would be more versatile.
But it's possible, you can't do that?
marsh
Post by marsh »
No, Menu>Tools>Batch Rename... is unavailable (grey) when browser displays <search results>.
Dreamer
Post by Dreamer »
marsh wrote:No, Menu>Tools>Batch Rename... is unavailable (grey) when browser displays <search results>.
Really strange why, because I can use batch rename, try Ctrl+A and F2. :wink:
Looks as a bug.
Dreamer
marsh
Post by marsh »
Looks as a bug.
That method works. Thanks. :)
