Multi Image Trouble..Error
RIVAL
Post by RIVAL »
hii..
i have problem with my program..i wont display 3 image from database sql server..n this code..
<!--#include file="../membership/common.asp" -->
Dim Path, file
dim path2
dim ctrl
Set ctrl = server.createobject("GflAx.GflAx")
Path = Server.MapPath("/img/")
path2 = "\"
const AX_JPEG = 3
dim sqll5
Set adoCon = Server.CreateObject("ADODB.Connection")
adoCon.connectionstring = strCon
adoCon.Open
Set rsCommon = Server.CreateObject("ADODB.Recordset")
sqll5="SELECT * from tblnews where news_category_id='19' order by Date_Create asc "
rsCommon.Open sqll5, adoCon
while not rsCommon.eof
file=(path & path2 & rscommon("default_image"))
<table width="200" border="1">
<tr>
<td><img src="<%
With ctrl
.enablelzw = True
.LoadBitmap file
.Saveformat = AX_JPEG
.SaveKeepMetadata = True
.UseTransparency = True
.FontName = "arial"
.FontSize = 12
.TextOut "SAMPLE", 12, 12, RGB(255, 255, 255)
' response.contenttype = "image/jpeg"
response.BinaryWrite .SendBinary
'response.write("JJJ :" & file)
end with
</td>
</tr>
</table>
rsCommon.movenext
wend
rsCommon.Close
Set rsCommon = Nothing
adoCon.Close
Set adoCon = Nothing
set ctrl=nothing
why image not display??..and this
error
Ÿû£ý=IY}Qp2OãQ¨3úGö@û€žÅ.ƒœ“¡Ë3”¾wdˆ(çØ1ê%È#z8×£%bç0\Y?‘#(ÀÞsUU>„ÀÎ.ðb÷ðÿâ]v¡STã©?_J¦JPí2UÕ¦iŽ??w÷÷öwNó'OžEQUÕt:][[ÛÜÜÜÜÜœLf?¾YÆbXÅñdXUE5(BˆŽàÈ ÉQç­ˆŽ/‹ªªÌÌ»óµ0°²²rxxȱ,Õ|Y[Ÿ¬—ë22-ÙÚ¦>>>ÞÝÝ}þüùó;‡ûG‹år8F0»àCáŠÇ’cÉ¡\,[SETcö…?Ñ{0?3L?R+"Éb¦è¸( !øªªLóÑá|¶¶d ƒQJ‰(“©#k–óÝ;»ÛŸöчGûËåR ©i?UDl2Y½¶6[[][[ŸNWªÑ¸,ËX”.øÉp5‰îîíK]YFfÁÑñ<¸8 LssÔªu¯äë;€WU˜?`5,‹”5µ0*æœK)ÍOŽ_¼xñé“?¶Ÿ}¾8Ükë…©†?wˆquíÚÆÆÆ?;wFÓÉlºZ…™©j—•?´LmÊÕ¨¨4Öí2%ÑlÁÇa1첤¶1dç­¼„Œˆ@g™.‚¦iÔÈÅØ,?LœsŸ~òñçŸ|²··×.O«2d“œ“+‹•é´Og«k³•U&s ‘T×Fܙ؛QÛµuÃNÕ†mëºÔX6çÜx8mšŽ?Nº®UåÊêØ(à.?qˆ0E¤m[?¤$"M½Xžž>þü³OŸìî<—ÔïRÝ2YYƪ,Š¢g¨¤®yöìÙ†ØÇràÈ9§$+“•”¨n–‹çGu}Ú´Ë"”“ñìYÚ)ËrXVDæÃ_6ß9üN×uusz||p°¿s|rHÆEQ¼ýÕÜÚºu{ëΩÎXÑ?噑ˆ€ÀÌ꺞/ë“““”ÒÞ‹?Ãý]•˜JOóùÀ?››£Ñ¨ªªlÈËæ£?|ý«o‹ÈïýÇûµ¿ø“Ëå²éN²Z9üó¿ÿ‹_ûÉŸýµø7/Üð~úçÚ¶þW¿üwÿô×ÿrˆ…‹ž~ö§¾~ÕUôèUUU‰u©9><2Âáþ^Ó4Ð\Äà ''Ë?Õéh\}úlç­¯¼qøù¿ñËMWÿ?_ø™õõõét à­úaÊX’wþɯ~óÁ«wð­GdtMFŒ±iyWDÞÙÙ99^Š©?ʲd(Á¢‹6onUÕàá½;óz™…8š¤’œé‹÷¾ýû0ý×ßø×ßÀßú«ÿìW~i²º†_ø™ßþÖomܺà?ÿ÷ßkšî?G¯__Yœ+Ù{ÁÕTó)%@½s½‘œsV‘Á WÓ¢ðôêƒû}ÿ1€õk³”쎞îήoum®®m-öžˆÕ´[ƒçu]µfÛ?ðÉ÷?èöÙÇ?÷ú§T£ÑpT•ÕÀ×ìO¾¤pè…À}€Í¬kŒ±,˪ªÊ2XÊ˺½±y½KÍþÁÑd\=z5EÀ€ ÀÆ8øñ?óÇ|íOýˆºâwÿÛÓ?­•Ùg¹qsm}6[›ÍüÖ}okãÚÃ{7ÎôÌe¥½€k!TUe„áp‚sìÚ¶ÍMûÑãÇ×Ö‰€÷ì=XYYiºÖM³0òàÚÀµñÀ½Í5ï¼ùàÇâ/ýË_ÿwðéN1Yðàî­[·¶6¯OG#“ɤ( ¼l—Z£—‡Ãáp8ðäØ{o&Òvu]·‹åÊÚêáþ€Éxà½ßÙÙ]™M4e¯Êl«Ãò`Ù¸¶^!:4»çèÚ,øöûAë‡oÜûòwîtIâüã_úÅþ¡ßü/ßðǾtÈ|_,ˆ¨w< `Z,fÒKû¾ÞÌ&SvÈ9›Ùp4e&*Cðäî?û·o¬Në“Ã×<­W´>þùûk]{ò•’þÞ?ø+ÝÞî·~ó?d?yý­wþÚ_ÿÛ?úgÿܲÕñt2®Æÿûñ^Y¸xksÊ—Á„¿ˆ£ªÂqÁ”º”êºf‰ö™w†Î`U@†AãjÈ*¹ÎëãáxsU›•ýÛh»’àM–)ß¹^}íÑoþ§oý?ÿõÞÃ7ßyõþ£?Æ•q0›M}QÎç'Î93ëÙûª <Ë3³³ïD”r®ëZDT?DSJ9gUe€™C¤ö6®†+ãrWçn~|t{ãþú­ëûãáñþ^d’Üqë~éÍ÷¾÷ä}ãÝ8^]ß¼½lu<Û¡MFD¨ë 05¨ªõZû—eÙu3bðª¨ëz±XQÄkŸø½×Ú&u]罟M¦+“i}Y„ÕÙäääøÃÞöìÙæææÝ»wë®}±»ŸÉõGþÄ?ýõßøøù±“ãŽú|™Ì\¬,–¹ Q1r¾â³ ½çzfÆÌDF¦ti B!8C(Š2„‘#jàtQøø£Ï>û¬ ~2¿yÿµÙÖíóÍßy¼³/ÞZ¹9Û¼³rãöh¶Î±4†HDêâw€êy&œsÌšUΑ?™/?Á¢F`€•XA †ç­;wóÓÔ5a:½{÷•??kMê¾ÿ|ﻟ½ jõÖí{¯<ú?[Þ¸ýêk7n?¦¼\BL»œ£Œ˜ü?¬ÿ¤jyï½·Ü]"£+¸9fBáC| ?=Xà":3W?&ëëM>Ú;|ÿƒï¾÷áöÝøá?ÛnÝ»_Í6’PÝt'óyÖª Q$kîr&gJưs÷\Dó<”æ˜bŒ9
thank for your help
Re: Multi Image Trouble..Error
RIVAL wrote: i have problem with my program..i wont display 3 image from database sql server..n this code..
Could you send me these 3 images?
