gflReduceNoise
Marty
gflReduceNoise
Post by Marty »
can't find the function in the vb bas files :(
MaierMan
Re: gflReduceNoise
Post by MaierMan »
Marty wrote:can't find the function in the vb bas files :(
Then add the declaration yourself.
should look like this (not tested at all):
Public Declare Function gflReduceNoise Lib "libgfle254.dll" (ByRef src As GFL_BITMAP, ByRef Dst As Long) As Integer
Fisch
lib
Post by Fisch »
How can I use this functions in the asp component?
Re: lib
Fisch wrote:How can I use this functions in the asp component?
Currently, not possible
