Is it possible to XnView read an image from "standard input" (stdin)?
I thought about a good workaround to "screen capturing" problem, but I will need XnView reading from standard input. My idea is simple. just run this on terminal:
$ sleep 2; xwd | xnview -
Where '-' would mean "read from stdin", just like most Linux utilities.
Above line does mean: wait 2 seconds, then, run xwd (X Window Dump) to capture the image. The output of xwd is redirected to input of XnView, which will open the image.
Read from stdin
Re: Read from stdin
You can use nview with stdincrazytb wrote:Is it possible to XnView read an image from "standard input" (stdin)?
crazytb
Re: Read from stdin
You mean xwd | nview -in xwd stdin. This works, but I want XnView functionality (toolbars, save, filters...), which nview does not have.xnview wrote:You can use nview with stdin
