Slideshow crashes when using mouse
Hendrik
Post by Hendrik »
Problem: The slideshow (the normal one) crashes, when the first command is given by clicking a mouse button. However, when I do use a key stroke as first command, the slide show can following be controlled by mouse without any problems.
The problem applies to the XnView program and gives the following crash information ("page fault"):
XNVIEW verursachte einen Fehler durch eine ungültige Seite
in Modul XNVIEW.EXE bei 0177:0043849e.
Register:
EAX=00000000 CS=0177 EIP=0043849e EFLGS=00010206
EBX=00000000 SS=017f ESP=0093f748 EBP=00000202
ECX=cf5b5260 DS=017f ESI=012fdaa8 FS=65a7
EDX=821cf03c ES=017f EDI=0093f7a4 GS=0000
Bytes bei CS:EIP:
8b 86 b0 0b 00 00 85 c0 74 1a 8b 56 08 52 ff 15
Stapelwerte:
012fdaa8 038202e9 00000009 000000ac 000002e9 00000382 0093f7ec 000000ac 0093f836 0093f804 012fd5f4 000000ac 00438dfe 00000000 0093f7a4 0093f7ec
I am using XnView 1.82.4 on Windows 98 SE and a quite new Logitech mouse driver. After burning the slideshow onto a CD-R, I could reproduce the malfunction on a Windows 98 system with a rather old microsoft mouse driver.
I didn't have this problem with the former version 1.68.1.
Thanks, Hendrik
Re: Slideshow crashes when using mouse
Hendrik wrote:Problem: The slideshow (the normal one) crashes, when the first command is given by clicking a mouse button. However, when I do use a key stroke as first command, the slide show can following be controlled by mouse without any problems.
You have the crash when you click on mouse button, but doyou have it even if you start slideshow from slideshow dialog box?
Hendrik
Post by Hendrik »
It crashes after pressing the mouse button.
Hendrik
Hendrik wrote:It crashes after pressing the mouse button.
But if start slideshow from the dialog box, do you have the crash?
Hendrik
Post by Hendrik »
Sorry Pierre, but I cannot reproduce the problem anymore. (Or rather luckily ...).
Hendrik
