EXR
Priceyza
EXR
Post by Priceyza »
Will or does xnview support exr images
Reading---
:) Hello !
• EXR is supported at reading only acording to the supported formats list.
- You can get that list online in a handier way, since sorted by extensions ON THIS PAGE.
:mrgreen: Kind regards,
Re: EXR
Priceyza wrote:Will or does xnview support exr images
FAQ "Does XnView support graphic format .xyz?" tells which formats are supported by XnView.
Post by Guest »
I cant seem to get xnview to display open exr files
Anonymous wrote:I cant seem to get xnview to display open exr files
Please, send me a sample?
Post by Guest »
Looks like xnview only supports .exr's that have compression? Because .exr's outputted from XSI are not shown, but after opening in Photoshop and saving another file it shows that one. (the one from photoshop is about 15-20% the size of the original)
Post by Guest »
OK, just checked it and XSI outputs with RLE compression (lossless)
Anonymous wrote:Looks like xnview only supports .exr's that have compression? Because .exr's outputted from XSI are not shown, but after opening in Photoshop and saving another file it shows that one. (the one from photoshop is about 15-20% the size of the original)
Could you send me a sample without compression?
gent_k
Post by gent_k »
Hi, I'm very sorry for the late reply, but I just forgot to check back in the forums. I'll upload an .exr that doesn't show up on xnview (it's a little big) on rapidshare and pm you the link.
