In XnView 1.82 using keyboard (F7) for creating folders in folder tree does not work very well:
The folder is created, but focus goes to somewhere else. I guess XnView tries to focus the appropriate folder in list of files, but I have display of folders deactivated. So I have to manually focus the new folder and rename the folder from "New folder" to what I want. Many steps for a little task.
Would be nice if after creating folders in folder tree the focus stayed on the folder in the tree and one could directly rename the appropriate folder.
Creating folder in folder tree with keyboard
Re: Creating folder in folder tree with keyboard
Ok, i'll check...helmut wrote:In XnView 1.82 using keyboard (F7) for creating folders in folder tree does not work very well:
