File Already Exists window size?
AstroCat
Post by AstroCat »
Is there a way to view a larger view in the "File already exsist" window.
Right now the images are so small it's hard to compare them.
Thanks.
No image here…
:) Hello, Welcome aboard !
• What do you mean exactly ? The message "File <xxx.yyy> already exists…" is coming -even in excess- while simply saving a file, and it is not an image-window.
- There is not any image there !
- Please, let show us a screen shot about this issue.
:mrgreen: Kind regards,
negg
Post by negg »
Just because I had this window open a few minutes ago: I guess AstroCat means the dialog you get when you try to copy/move an image with the command in the context-menu:
While this image might be useful sometimes I don't think there is a way to enlarge the image thumbnails there.
XnView 1.93.4 on Windows XP SP2
AstroCat
Post by AstroCat »
That is the screen. Thanks for the screenshot.
When I drag a new file in to the XnView main window I get that window above.
Often I am replacing a file with the same name but one is an updated version.
It would be very helpful if I could view those 2 files in full size to compare the differences. This way I can choose the old or new file.
Thank you for your help.
