Why is there no 'Save' button for XnView Image View 1.82.4?
c627627
Post by c627627 »
I'm editing multiple files and when I'm done, I have to go to File > Save because there is no Save button.
Would you please consider adding this button in future versions?
'Save As' button is there but this is not a 'one click' solution when you are editing multiple files.
Thank you.
Frozen--
:) Hello !
• It is not possible to add any button in the tool-bars without changing all skins.
- Please, see this thread and use the Search to find others which explain that issue…
- I would like too a simple "Save" button, without this stupid exasperating message "to replace" the file : this is the same file, just save it, it replaces nothing :twisted:
:mrgreen: Kind regards,
