Searching TIFs using IPTC-field - no?
Troken
Post by Troken »
Hi all,
not sure wether this is a bug or not. When doing a search in the IPTC-field, XN-view only searches through JPGs? I tried with tagged TIFs but no results. I know XN-view does not tag the IPTC-field in TIFs yet, but would it at least be possible to add a search-function?
Thanks again Pierre, for the software. Hey, btw, do you have any sort of donating-thing? I would happily pay something, it's really worth it, man.
/Troken
Re: Searching TIFs using IPTC-field - no?
Troken wrote:Hi all,
/Troken
Yes, currently it's only on JPG, i'll try to add search for tiff too
