PowerBuilder Code examples?
bob_chauvin
Post by bob_chauvin »
Looking for a code examples related to PowerBuilder.
Anyone seen any?
bob_chauvin
Yahoo Messenger: [email protected]
Example done.
:D OK, I have an example app if anyone needs it.
Bob C.
Re: Example done.
bob_chauvin wrote::D OK, I have an example app if anyone needs it.
Bob: Perhaps this sample could make it into the GFL package - if you don't mind?!
Pierre: What do you think of this idea (source code shouldn't make the package much larger)?
bob_chauvin
Including PB Sample. Sounds great!
Let me know if Pierre is interested in including the sample.
Bob C.
Re: Including PB Sample. Sounds great!
bob_chauvin wrote:Let me know if Pierre is interested in including the sample.
Yes, of course :-)
bob_chauvin
Powerbuilder 9.x Samples are ready.
Sorry for the delay. Had a hardware problem, and took a while to get back to the files needed.
Anyway, Pierre, here is a link to the samples.
http://us.f1f.yahoofs.com/bc/3244135e_L ... BB6PcuHuwl
Bob C.
Re: Powerbuilder 9.x Samples are ready.
bob_chauvin wrote:Sorry for the delay. Had a hardware problem, and took a while to get back to the files needed.
Sorry the link is not available!
bob_chauvin
Another try at posting a link to the file.
http://us.f1f.yahoofs.com/bc/3244135e_L ... BBEtZwHuwl
If this d/n work, I can email the file to you, Pierre.
Bob C.
Re: Another try at posting a link to the file.
bob_chauvin wrote:http://us.f1f.yahoofs.com/bc/3244135e_L ... BBEtZwHuwl
Don't work too :-(
Could you send me by email?
Both links do not work for me either.
bob_chauvin
I can send a sample via email, just need an address.
-bac
Bob C.
Re: I can send a sample via email, just need an address.
bob_chauvin wrote:I can send a sample via email, just need an address.
-bac
Bob,
Would be good if you sent the samples via mail. You can contact Pierre directly via [email protected] (please remove '-nospam').
Thanks & Cheers,
Helmut
bob_chauvin
Sample sent to Pierre via the address you supplied...
Hope it proves usefull for others..
I have referred others to this tool...
Thanks Pierre et.al.
Bob C.
