High quality zoom
High quality zoom
Post by Guest »
I tried Gwenview on Linux (KDE) the other day, and I was very impressed with its high quality zoom. It had a bunch of ways to zoom pictures, one of them was called "bilinear" I think. It would be wonderful if I could have that on Windows. Most of my pictures look like pixelated garbage when they're automatically zoomed in full screen mode.
Hitman
Post by Hitman »
You can enable such thing as "Reduce" option, under some options menu... it makes image look perfect on XnView ... though it is realy SLOW...
darkfader
Post by darkfader »
I find the high quality zooming in XnView too slow.
It is probably better to use/show at normal quality first and then the high quality.
Olivier_G
Post by Olivier_G »
'High quality' is bilinear. There is an option for 2 passes (fast first, high quality then) in Options>View>Fullscreen.
Here is an interesting thread about speed improvements for high-quality.
Olivier
darkfader
Post by darkfader »
Ah thanks for the redirect.
I hope that delayed high quality will be added for normal normal view as well.
