Choosing fields in Metadata export IPTC/EXIF
rbeek
Post by rbeek »
I'm very happy with this feature in the newest release.
However...... Is it possible to choose the fields you wish to export?
As the txt and CSV option are working very fast (the XML gives problems) I am interested in certain fields.
Re: Choosing fields in Metadata export IPTC/EXIF
rbeek wrote:I'm very happy with this feature in the newest release.
Currently you can't select output fields, but will be a good enhancement...
rbeek
Post by rbeek »
Hi Pierre,
Thanxs for the answer. Iw ould be very pleased!
Fotostation (Classic) has this option also. There is however a little pricedifference!
René
