Slide Show (exe) crashes
cs
Post by cs »
I just found that the slide show (exe) is crashing on my computer when having "loop" not selected and going backwards (by mouse/button) after the start (first) picture. It is working when "loop" is selected.
Can anyone reproduce this?
Thanks
Carsten.
Re: Slide Show (exe) crashes
cs wrote:Hi,
Only if 'loop' is enabled?
cs
Post by cs »
with "loop" enabled it is working fine.
But with "loop" disenabled/not selected it crashes when going backwards from start-picture by mouse or arrow-button (instead of staying at the first picture or just closing the slideshow).
Maybe I should check how the slideshow (exe) behaives at the end after the last picture (with "loop" disabled)?.
Thanks Carsten.
cs wrote:Hi,
Do you have the problem in the normal slideshow?
Post by Guest »
no, only in the EXE build!
Thanks Carsten.
Anonymous wrote:Hi,
Thanks Carsten.
Ok, i'll check
Post by Guest »
I tested a litte bit more on this issue and found out that the build exe-file behaives like this when it is larger than about 1170kb. Below this value (in my case 1148kb) everything is fine. And above (1179kb) it crashes like described above.
Might there be the problem?
(I have 26 picture 800x590, 16M, JPEG TC (1.1) all between 25kb and 50kb, running WinXP with all patches and updates)
Thanks Carsten.
Post by Guest »
after a little bit more testing, I found the following:
exe-file only crashes when having that certain file-size (see above) and using the mouse buttons to change pages. It crashes at the beginning (when using left mouse button at first image) and at the end (when using right mouse button at last image).
When using the keyboard cursor-button everything works fine!
Is it a program specific issue or is the problem on my side (I will test it on a different pc later...)?
Thanks Carsten.
Anonymous wrote:Hi,
It's a bug
