Cache works only in thumbnail view ...
gemp.scan
And if I switch to details or any other view, images doesn't cached. Please fix this
Re: Cache works only in thumbnail view ...
Sorry but could you explain more. I don't udnerstand your problem.gemp.scan wrote:And if I switch to details or any other view, images doesn't cached. Please fix this.
gemp.scan
In browser switching view "Thumbnails" with any other (details, list, icon) cause images not cached. It can be easily checked in cache options, look at list of cached directories. So when i return to the already viewed directory, it loads very slow.Sorry but could you explain more. I don't udnerstand your problem.
And one more thing, does xnview support interpolation of images? They look ugly in preview area in any zoom, that differs 100%.
Sorry for my english, itsn't very good.
You mean:gemp.scan wrote:In browser switching view "Thumbnails" with any other (details, list, icon) cause images not cached. It can be easily checked in cache options, look at list of cached directories. So when i return to the already viewed directory, it loads very slow.Sorry but could you explain more. I don't udnerstand your problem.
In browser, the thumbnail view is cached. When switching to another type of view (e.g. menu 'View->View as->Icons'), the browsed folders and their files are not cached.
Not quite clear whether this is a bug: For the icon, details, and list type view, only parts (basically the header and file info) of the image data is loaded. This is fast (a lot faster than viewing thumbnails). Naturally caching is not done, since this would require reading all the image data.
That's just my understanding, Pierre knows more details.
Yes, I mean exactly that.You mean:
It isn't so, XnView also renders the pictures, not only headers, look at progress bar, which appears in the down right corner. Besides, it takes a lot of processor time. So what i have to do, if i don't like thumbnail type of view?Not quite clear whether this is a bug: For the icon, details, and list type view, only parts (basically the header and file info) of the image data is loaded. This is fast (a lot faster than viewing thumbnails). Naturally caching is not done, since this would require reading all the image data.
p.s.There are no such problem in acdsee3 and higher, but itsn't freeware.
