Raw RGBA=>BGRA
Ulf
Raw RGBA=>BGRA
Post by Ulf »
is there any way to import raw bitmap files with another format than that included in the raw import options dialog?
Specifically there is RGBA or BGR, however I would need BGRA. I know that I can cycle colors, which works fine, but this involves a couple of additional steps.
Thanks
Ulf
Re: Raw RGBA=>BGRA
Ulf wrote:Hi,
Sorry but currently not possible
Ulf
Post by Ulf »
Never mind - maybe you could keep in mind as a feature wish for your great program.
Thanks!
