Saving a previously imported RAW image
Ulf
Post by Ulf »
I imported a RAW image (RGBA) which is correctly desribed as a 32 bit image. After doing some changes (mirroring, ...) I close the file. Then I'm asked if I want to save the file - which I answer by Yes.
The file is saved as a RAW image again, however with 24 bit color depth only.
I think this should be 32 bit as well.
Thanks
Ulf
Re: Saving a previously imported RAW image
Ulf wrote:Hi,
Yes, i'll check...
