XnView 1.68.1 crashes when open a JPEG file
gzliudan
Yahoo Messenger: gzliudan
Post by gzliudan »
When I open a JPEG file, XnView 1.68.1 crashes everytime. But I can use other image software to open this file. My OS is Windows XP with all current patches installed. The problem is same if I use another XP computer. If anyone is interested at this problem, I will mail this image file to him.
With Best Regards
Daniel
Aokromes
Post by Aokromes »
Try downloading 1.70 rc2 to check if it crashes too.
Post by Guest »
Aokromes wrote:Try downloading 1.70 rc2 to check if it crashes too.
Yes, XnView 1.70RC2 has not this problem. The problem is releated to fit option in 1.68.1. My fit option is "fit to window, all". If I change fit option to fit no, then the problem disappear.
