I am trying to 'auto contrast' a bunch of *.ecw files that are placed in several subdirectories.
When I select these directories in the browser window and execute the Tools\Batch convert command XNview starts thinking for several seconds.
When the Batch convert dialog opens, no files/directories are selected at all!
no recursing subfolders when selecting ecw files
Re: no recursing subfolders when selecting ecw files
Yes, with the current version you can't use subfolders...MichelV wrote:Hello,
MichelV
Okay that explains itxnview wrote:Yes, with the current version you can't use subfolders...MichelV wrote:Hello,
I've copied them all into one dir and'll split them later.
Thanks,
Michel
