Problem with printing eps file...
navram
sir,
when i print eps file using gflax component i get very low quality
printout. but if i am using tif or jpg it gave very clear output... why
is this... please help me....
u can see my code here:
Sub PrintImage
On Error Resume Next
Dim MyObj As GflAx.GflAx
Set MyObj = New GflAx.GflAx
MyObj.LoadBitmap "c:\test.eps"
Printer.PaintPicture MyObj.GetPicture, 10,10
Printer.EndDoc
End Sub
plz help me....
Sub PrintImage
Printer.EndDoc
End Sub
plz help me....
Re: Problem with printing eps file...
you must use EpsDpinavram wrote:sir,
Sub PrintImage
Printer.EndDoc
End Sub
plz help me....
navram
i use EPSDPI but still i don't get a better results...
can u plz tell me how to use EPSDPI for better result....
ram
ram
navram
any body there to help me....
i am in big trouble help needed urgently....
please tell me how to print eps files with good clarity.....
when i try to print eps file using gflx component the clarity of eps file is very poor.... but if i print any other file format (jpg/tif) it print with very good quality....
i use EPSDpi to increase the printing quality....
but it doesnot have any impact....
plz help......
plz help......
Send me a sample, please?navram wrote:i use EPSDPI but still i don't get a better results...
navram
sir
i have emailed you my project... plz check that and help me to get full printing quality of eps files....
navra
navra
I have not received itnavram wrote:sir
navra
navram
sir
i emailed my project in this email address
<!-- removed //-->
whether u have any other mail address let me know... so i can mail u in that address also.....
thanks... in advance...
<!-- removed //-->
navram
sir,
i mailed u my project in <REMOVED>
i think u get it....
plz help me....
plz help me....
It's the good email, but have not got itnavram wrote:sir,
plz help me....
navram
you can download my project from the following links.... please go through it....
password for the zipfile is: navram
http://www.filefactory.com/?af98f0
or
http://www.oxyshare.com/get/79493556644 ... x.zip.html
or
http://www.oxyshare.com/get/12388711374 ... 1.zip.html
navram
or
or
navram
Sorry, but these download link don't work...navram wrote:you can download my project from the following links.... please go through it....
or
or
navram
navram
sir,
the oxyshare link work successfully... i even tested now youwant to click the link and scroll down and click Get Your File.... after that you want to wait 30 seconds... then you can download my project...
Ok, i've fixed the problem, could you send me an email, i'll send you the fixed version...navram wrote:sir,
navram
sir,
i have emailed you.... plz send me a fixed version as soon possible....
plz help
ram
nav_ram @ rediffmail.com
plz help
ram
