"error converting awd file to TIFF" error when sea
AP2000
Post by AP2000 »
Has anyone seen this problem with Xview 1.82.4?
When I try to search for All graphic files in some folders, I get:
The options ticked are include subfolders and Format is All Graphics formats.
The last folder before it crashes is C:\Documents and Settings\cczap.AD\Application Data\Lavasoft\Ad-Aware where there is a stats.awd files, which is not a graphics file.
I assume Xview is trying to convert a non graphics file to a graphics one?
Thanks in advance.
Re: "error converting awd file to TIFF" error when
AP2000 wrote:Has anyone seen this problem with Xview 1.82.4?
Ok, could you send me the file?
Post by Guest »
ok sent file to <!-- removed //-->
Anonymous wrote:ok sent file to <!-- removed //-->
no please to [email protected] (remove -nospam)
ap2000
Post by ap2000 »
Ok done....
AP2000
Post by AP2000 »
Was the file received? The program crashes out with a sent MS an error report etc with xnview.exe
I have tried this at home and at work and does the same and halts on the Adaware folder.
AP2000 wrote:Was the file received? The program crashes out with a sent MS an error report etc with xnview.exe
Ok, it's the plugin that show this dialog, you can delete Xawd.dll
AP2000
Post by AP2000 »
Did you get my email about XNVIEW crashing out when browsing a folder with a PRT file in there?
AP2000 wrote:Did you get my email about XNVIEW crashing out when browsing a folder with a PRT file in there?
Yes, thanks
