gflLoadThumbnail D4/Win98: wrong NumberOfImages for GIF ?
klaus2
Post by klaus2 »
may it be the case that, on GIF images, gflLoadThumbnail with Delphi 4 / Win98
returns wrongs results for finfo.NumberOfImages (always "1") ? // libgfl 2.54
This result is
- different to using the same code with Delphi 6 / Win2K
- and different to the result given by gflLoadBitmap.
Any points of direction would be helpful.
Best Regards,
klaus2
klaus2
Post by klaus2 »
Seems to apply to gflGetFileInformation too
(more ugly, because i want to have the correct information, although i don't want to display animated gif with libgfl).
klaus2
Post by klaus2 »
About gflLoadThumbnail, i did an error (in fact, gif nbrOfImages does _not_ work with D6/W2K;
also it is an already known issue) - so forget.
About gflGetFileInformation: is it assumed that it should provide the info?
Best Regards,
klaus2
klaus2 wrote:Hi,
The problem with gif is that i must decompress all frames to know how many frames are in the gif.... :-(
Alessandro
Post by Alessandro »
If I got it right Pierre already answered to this question.
Use gflLoadBitmap to get the correct number of frames...
I hope this helps
