I am trying to convert a .fit file to jpg. The fit file was created using IEEE
64 bit floating point numbers.
The Fits file header is:
Headers for HDU 1
SIMPLE = T /
Java FITS: Mon Jun 12 00:24:44 CDT
2006
BITPIX = -64
NAXIS = 2 /
Dimensionality
NAXIS1 = 100
NAXIS2 = 100
EXTEND = T /
Extensions are permitted
For trying to convert this i get the following error:
Error: FITS: Bad Bits Per Pixel !
However, the same file stored where each pixel is stored as a short value
(instead of a double), which header is:
Headers for HDU 1
SIMPLE = T /
Java FITS: Sun Jun 11 23:10:15 CDT
2006
BITPIX = 16
NAXIS = 2 /
Dimensionality
NAXIS1 = 100
NAXIS2 = 100
EXTEND = T /
works just fine with no errors.
I could not find a way to work around getting the 64 bit FP number version to work as well. Does nconvert support this type of fit file, and
would it be possible to convert it to a jpg/gif?
Thank you so much for any help,
Best,
Gabri
.fit types supported
Re: .fit types supported
Could you send me some samples, please?gabri wrote:Hello,
