SE: Open selected images only
DanM
Post by DanM »
<Moderator's note: This topic has been split from another topic>
In PicaView you could select several images at once and then right-click and open the viewer. When you scrolled through them with Page Up/Page Down, it would show only the images selected instead of all of them in the folder. It'd be great if that was also included in XnView.
Thanks,
-Dan
DanM
Post by DanM »
I see some notes in
http://newsgroup.xnview.com/viewtopic.php?p=25198#25198
that say, "use mouse wheel to switch between images - selected or all in the current folder." This sounds similar to what I suggested, but I'm not doing something right. Does XnView support viewing pictures this way?
Thanks,
-Dan
