desperate with TIF compressions: how can I convert a file into TIF with CCITT Group 4 compression ??
The option offered in the save-options "binary options" CCITT G4 doesn't really get the result I wish.
For a single page I expect a 1 Bit file with about 100kB size.
All my trials lead to either a LZW-compressed or jpg-compressed 24 Bit file.
Thanks for your help!
Pascal
XnView 1.50: save as TIF CCITT Group 4 compression
Re: XnView 1.50: save as TIF CCITT Group 4 compression
First, use the 1.68.1.Pascal wrote:desperate with TIF compressions: how can I convert a file into TIF with CCITT Group 4 compression ??
Your original file is in 24bits?? Use Image/convert binary, before to save it.
David_T
