edit EXIF Comments in Image properties
raducoc
I know is possible to edit the EXIF Comments in Edit/Metadata/Set comment... , but I think is more easy to edit the EXIF Comments directly in Properties (Alt+Enter). Or maybe double cliking in the Column "Comment" to enter in EXIF Comments editemode. I think this ways is more easyest and more convenients. Now, if Im doublecliking in the Comments column field, XnView is switching to fullscreenmode and in Image Properties I have no option to edit the EXIF comments. Please, if is possible to change the behavior of this things. Thanks in advice.
Re: edit EXIF Comments in Image properties
The next version will have a better way to edit it...raducoc wrote:I know is possible to edit the EXIF Comments in Edit/Metadata/Set comment... , but I think is more easy to edit the EXIF Comments directly in Properties (Alt+Enter). Or maybe double cliking in the Column "Comment" to enter in EXIF Comments editemode. I think this ways is more easyest and more convenients. Now, if Im doublecliking in the Comments column field, XnView is switching to fullscreenmode and in Image Properties I have no option to edit the EXIF comments. Please, if is possible to change the behavior of this things. Thanks in advice.
