Hello, I was looking for a nice picture viewer and came across xnview. I thought everything was fine until I realized that pictures have many squares compared to the same pictures viewed with windows basic viewer (I use viewers to read manga)
So I was wondering if there wasn't some kind of tweak in the settings to make the render smoother by default.
Thanks
Alexikiki
pictures are "pixelly"
Please, more info
• I didn't encounter such an issue…
- Please, try to press the [*][/size] key when you read such a picture.
- I think that you could have the settings for "Fit to window" thus a blown up image; with that command you'll get the pic as 1:1 scale, and pixels couln't be visible…
• If that doesn't solve the problem, please let show us a screen shot, and give more info about your settings…
- Forum Librarian
Re: pictures are "pixelly"
Go to Tools » Options » View and activate High zoom quality (slower) for Reduce, Enlarge & Fit to Windows/Desktop.alexikiki wrote:So I was wondering if there wasn't some kind of tweak in the settings to make the render smoother by default.
