WMF file fails to display / convert correctly
[email protected]
Post by [email protected] »
(I know very little French, so I hope I fill this in correctly.)
We have encountered a WMF file that does not display correctly in XnView, nor does it convert correctly using the GFL SDK.
I can load the WMF using Paint, or Word and it looks fine. When loaded in XnView, the view size would appear to be correct, but you only see a small portion of the bitmap component as though it was zoomed in and the rest of the bitmap is outside the frame view.
My general guess is that the reported size of the bitmap does not match the scale to which it is rendered.
I would attach the file, but I'm not sure where to upload it. If you contact me by email, I'll send it to you. In fact, I'll send Pierre a message with the attachment now.
Re: WMF file fails to display / convert correctly
[email protected] wrote:(I know very little French, so I hope I fill this in correctly.)
Ok, i have the file, i'll check
[email protected]
WMF File problem
Were you able to reproduce the problem?
Thanks for looking at it. Please drop me a line on your progress.
SEK
Re: WMF File problem
[email protected] wrote:Were you able to reproduce the problem?
Yes, but don't understand why this wmf is loaded like that...
