any help would be appreciated
i want to create thumbnails of eps files using nconvert. at first it was not possible but after downloading AFPL Ghostscript it goes ok. BUT...
after thumbnail generation when i try to open the created thumbnail with photoshop the first thing i see is a window titled "Rasterize Generic eps format". well if i complete the procedure and save the file as eps from photoshop, then and only then, the file thumbnail is viewable from my custom made thumbnail-viewer. The original file opens from photoshop without any problem. is it something i do bad on conversion?
ghostscript 8.5.3
nconvert 4.57
line of code i use
nconvert -quiet -ratio -resize 150 150 -o rr.eps aluit-la.eps
thanx in advance
eps file does not open after resize
Re: eps file does not open after resize
But nconvert can't save EPS, i have only a small coder for PSwizard wrote:any help would be appreciated
ghostscript 8.5.3
nconvert 4.57
line of code i use
thanx in advance
