Using TWAIN with GFL SDK
Kossman
Post by Kossman »
I would like to acquire images from a TWAIN source (scanner) and use the GFL SDK to view/edit and save the image as a multi-page TIFF.
Does anyone use or know of a TWAIN control or DLL that works well with this SDK, or have any other suggestions?
At present I use the Victor Image Processing Library in VB to acquire and save the image, but it doesn't support 4-bit grayscale, and the bitmap structure it uses doesn't seem to be easily converted to the GFL SDK bitmap structure.
bob_chauvin
What platform are you using?
Post by bob_chauvin »
Is this for Windows, or some other platform?
Bob C.
Kossman
Re: What platform are you using?
Post by Kossman »
I'm using Windows and VB6.0 at the moment, but may use VB.Net later.
bob_chauvin
Twain
MS Paint and MS Photo Editor both allow for TWAIN acqusition. I've been looking for an API for either of those, but no info yet...
I have used Visionary Solutions toolset (http://www.visolu.com), though they do have a runtime license fee.
Bob C.
bob_chauvin
Twain
Bob C.
bob_chauvin
Twain
And also... This is a C++ implementation of TWAIN
http://www.codeproject.com/audio/twaintest.asp
Bob C.
bob_chauvin
Twain
Bob C.
bob_chauvin
TWAIN
Bob C.
Kossman
TWAIN
Post by Kossman »
Thanks a lot Bob, I'll follow these up.
Colin
