Add text seperator "|" problem
marsh
Post by marsh »
I used the following in add text:
"*.*|WMV MOV MAX"
It pasted correctly.
When I pasted a second time, the seperator character was corrupted inside input box- it changed to a "nul" string or something.
I saw same…
:) Hello B. !
• Do you mean that a string in the clipboard has been changed¦damaged ?
- I see often a similar issue when I edit resources in ResourceHacker, the inactive "Art" quotes #147 and #148 are changed into keyboard quotes " " that indeed causes an error !
• However, this doesn't occur with other programmes, let's say usual text-editors.
- Hence, I think that some programmes can perform faulty calls about the copy¦paste operations with the clipboard ;)
:mrgreen: KR
marsh
Re: I saw same…
Post by marsh »
Clo wrote::) Hello B. !
Perhaps, but I think it more likely that character isn't stored properly in xnview.ini correctly- so it can't be rememebered right for subsequent pastes.
Odd…
:) Weird… That character exists in all charsets and fonts, even in the crappy MS Sans Serif as :
| #124 - Vertical bar, according to the M$ specs.
- Let's wait for the Pierre's opinion… :wink:
:mrgreen: KR
Re: Add text seperator "|" problem
marsh wrote:I used the following in add text:
"*.*|WMV MOV MAX"
Yes, right, '|' is used as internal character :-(
The other…
:arrow: Pierre
:) Hello !
• Suggestion :   Since the pipe #124 | is used in the programme itself,
maybe could we use the dashed one #166 ¦ as separator ?
:mrgreen: KR
Dreamer
Re: The other…
Post by Dreamer »
Clo wrote::arrow: Pierre
:) Hello !
:mrgreen: KR
Hmm... I can't see it on my keyboard.
Dreamer
In vogue before…
:D It was standard AltGr+6 Alpha on the old IBM French keyboards instead | !
- I've still one here just close me ! Tireless (1kg !).
- But this is not a problem to type Alt+0166, isn't it ? I use this a lot in some translations instead "/" to save room in narrow controls and to get clearer strings…
:mrgreen: KR
marsh
Post by marsh »
OT: Wikipedia has pictures of various keyboards.
http://en.wikipedia.org/wiki/Internatio ... rd_layouts
