Tooltip doesn't hide, Directory cannot be renamed
Roti
Post by Roti »
Hi!
We use this great software day by day at the company.
I have found two things to check in 1.70 RC3:
1. Tooltip
In another windows program, when I have a tooltip, and I change task by pressing Alt+Tab, this tooltip will disappear. When I have a tooltip in XnView, and change task with Alt+Tab, it won't disappear, and I have to wait some seconds to get rid of the tooltip. I think the tooltip should disappear as soon as I press a key, at least the Alt key.
2. File/dir lock
When I browse a directory structure with XnView, and go down some levels, and back again to the top, I still can't rename the visited folder.
Ex.: go down to c:\temp\01\02 ; and back to c:\temp , after it, in total commander I can't rename c:\temp\01\02 to c:\temp\01\03.
Roti
Re: Tooltip doesn't hide, Directory cannot be renamed
Roti wrote:1. Tooltip
Yes a little problem.
2. File/dir lock
Strange, i have not this bug. Which OS?
Roti
Post by Roti »
The file lock problem details:
Winxp client, redhat samba server
When I use another image viewer program, I can't rename a folder which I currently view with the program, but when I change dir, I can rename.
With XnView, I have to quit.
