FFDShow - Freeware
Dreamer
FFDShow - Freeware
FFDShow - Freeware
FFDShow Homepage
FFDShow Homepage (old)
FFDShow is a set of DirectShow filters and VFW codec for video compression, decompression and processing and audio compression and processing.
Features:
- DivX, Xvid support
- Subtitles support
- Keys & remote - keyboard shortcuts...
- OSD
- Deinterlacing
- Crop & zoom
- Logoaway - to hide ugly/moving logos/icons
- Picture properties - to change contrast, brightness, gamma...
- Blur & noise reduction
- Sharpen
- Noise
- Perspective correction
- Bitmap overlay - to add images
- Grab - to make snapshots
- And other unique features...
FFDShow Homepage
Features:
- Subtitles support
- OSD
- Deinterlacing
- Crop & zoom
- Sharpen
- Noise
Dreamer
ckit
FFDShow MPEG-4 Video Decoder 2006-10-27:
http://www.free-codecs.com/download/FFDShow.htm
Dreamer
FFDShow 2006-11-04 has been released.
Notes about latest versions of FFDShow MPEG-4 Video Decoder :
- FFDShow 2006-08-28 (rev. 2546) was compiled by drevil_xxl using GCC 4.1.1 (libavcodec.dll & libmplayer.dll), FFDShow 2006-11-04 (rev. 497) MMX* was compiled by clsid using MSVC 7.1 (ffdshow.ax, etc) + GCC 3.4.5 (libavcodec.dll, mplayer.dll, kerneldeint.dll) while FFDShow 2006-08-03 (rev. 2546) SSE** was compiled by videomixer9 using ICL 9.1.028 + GCC 3.4.5.
* Only for CPUs with support for MMX (MultiMedia eXperience) instructions.
** Only for CPUs with support for SSE (Streaming SIMD Extensions) instructions. Check if your CPU has support for SSE or SSE2 instructions using Cpu-Z, a small tool which shows infos about CPU.
First of all, the FFDSHOW consumes way less CPU power than original DivX codecs, even with maximum post-processing. At the same time the post-processing seems to give excellent quality results and allows more configuring than the original DivX 5 codec. It can even automaticly reduce post-processing if your CPU is getting overloaded. The noise filter adds a kind of a rasterising effect to the picture - might be useful in some cases. The alpha version also includes experimental playback for MPEG-1 and MPEG-2 files (such as VCD and SVCD movies), which works pretty damn well. Only problem is that MPEG-2 playback can't play the SVCD clips directly from the CD, but requires the video to be extracted to the HDD by using VCDGear first.
Dreamer
ckit
FFDShow MPEG-4 Video Decoder 2006-11-09:
http://www.free-codecs.com/FFDShow_download.htm
Both MMX and SSE versions updated (I'm using the SSE version)
ckit
FFDShow MPEG-4 Video Decoder 2006-11-13:
Only MMX version updated!
ckit
FFDShow MPEG-4 Video Decoder 2006-11-16:
All versions updated!
Homepage(s) have been changed, thanks ckit. - Dreamer
ckit
CLSID's version 2006-11-23 updated - http://sourceforge.net/projects/ffdshow-tryout/
Change log - http://svn.sourceforge.net/viewvc/ffdsh ... /?view=log
ckit
CLSID's version 2006-11-27 updated - http://sourceforge.net/projects/ffdshow-tryout/
ckit
CLSID's version 2006-12-01 updated - http://sourceforge.net/projects/ffdshow-tryout/
ckit
Drevil_xxl's FFDShow SSE and SSE2 rev. 621 - http://sourceforge.net/projects/ffdshow-tryout/
ckit
CLSID's FFDShow MMX rev. 641 - http://sourceforge.net/projects/ffdshow-tryout/
ckit
CLSID's FFDShow MMX rev. 654 - http://sourceforge.net/projects/ffdshow-tryout/
ckit
CLSID's FFDShow MMX rev. 664 - http://sourceforge.net/projects/ffdshow-tryout/
Anyone know the difference between ICL9.1 and non-ICL9.1 builds?
foxyshadis
ICL means the ffdshow part (the filters, mainly) is compiled with Intel compiler. It's sometimes much faster than microsoft's (MSVC), most strongly affecting the deinterlacing and noise removal. The decoders, encoders, post-processing, and resizing are all compiled by gcc 4.1, so they don't benefit from the speedup.
