Suggestion: Auto-Search for best save-format
Mr-Fly
Post by Mr-Fly »
Hi.
What would be a great feature:
An Menu entry for save, which will then search the best save-format out of a predefined list.
The best could mean eg. for size.
I often try different formats to get the smallest files, which is sometimes jpg, sometimes png, but if it is a scanned page it can also end up as gif.
So it would be nice, if I could define the possible formats (jpg,png,gif,pcx) and xnview will check which of them suits best.
Regards
Thorsten
Re: Suggestion: Auto-Search for best save-format
Mr-Fly wrote:Hi.
In next version you'll have an export feature, and you'll see how is saved the picture...
Mr-Fly
Post by Mr-Fly »
Great.
Will there be a public betatest again ?
Regards
Thorsten
Mr-Fly wrote:Great.
I'll put soon an alpha, and yes there will be public beta test...
