Qtek 8310 ?
Discussions on XnView for PocketPC
alexandre
Qtek 8310 ?
Post by alexandre »
None of the existing installs seems to run on my Qtek 8310 (I tried them all). Do you guys plan to make one available ?
Thanks and regards.
Alexandre
Re: Qtek 8310 ?
alexandre wrote:Hello,
Thanks and regards.
Alexandre
What OS do you have on it?
ptepicchamon
Post by ptepicchamon »
It's Smartphone WM 5.0.
I have the same device and would appreciate it too.
moe
ptepicchamon wrote:Hello,
Which resolution do you have on it? 240x320?
Ptepicchamon
Post by Ptepicchamon »
Exectly. I's 240x320
Ptepicchamon wrote:Exectly. I's 240x320
And what's happened when you install it?
Ptepicchamon
Sorry for bothering you with this. So Qtek 8310 is (same as I-Mate SP5) windows Mobile 5.0 smartphone. Not a Pocket PC. When I try to install it, installation ends with error message that says something like this software is not meant for this device.
The initial question should more likely be Whether you plan to release smartphone version and when.
Ptepicchamon wrote:Sorry for bothering you with this. So Qtek 8310 is (same as I-Mate SP5) windows Mobile 5.0 smartphone. Not a Pocket PC. When I try to install it, installation ends with error message that says something like this software is not meant for this device.
Could you send me an email, it will be easier :-)
