Capturing minimizes the window
Troken
Post by Troken »
I wonder if anybode else have encountered the following:
I always have the window maximized when using XnView. But when capturing an image from another program (which I do quite often), XnView minimizes the program-window after the capture. This in not a terrible bug, only annoying sometimes.
Anybody?
Cheers!
Hi Troken :)
I use the F10 key to trigger capturing. When I hit it to make a screenshot of a program window — like my web browser, for instance — XnView pops up in front of Firefox with the captured screen, and XnView's window gets resized as if I had clicked on the Restore button. It's not minimized, though.
marsh
Post by marsh »
Good eyes, Troken. :)
Confirmed (maybe). After returning from capture, Xnview does not remember its maximized state. It goes to a normal state instead. At least, I thought you were reporting this...
Troken
Post by Troken »
Hi XnTriq & marsh,
yes you're right, I meant restored window and not minimized, as you both noticed. But at the time, I couldn't find the right word for it in english :wink:
Then I guess it's a minor bug. Perhapps easy to fix?
This could well be a feature instead of a bug, don't you think?
I'm serious: Maybe Pierre wants to give users a chance to compare their screenshot with the window they captured.
Troken
Post by Troken »
Nooo... you think so?
If true thats there's a thought behind it, better to make it an option instead.
EDIT: On 2nd thought, no, no more options, there's enough of 'em anyway :) I rather have my window the same size.
Post by Guest »
I vote for restore the window.
May be an option in the "Capture window"
Maximiliano
Troken
Post by Troken »
I think this has been resolved in the Alpha 3; the window is restored as it was before the capture. Thanks!
