File selection disappears when deleting file
notnoisy
Post by notnoisy »
I select a file in the list, and delete it (pressing "delete"). File disappears, and XnView insists on refreshing the entire list - forcing me to find back the point in the list I was at.
How difficult can it be to fix this? So far I have never encountered a grid-component that doesn't let you select the next row after removing one.
This is making file management really difficult in XnView.
Other than that - great program.
Re: how difficult can it be?
notnoisy wrote:I select a file in the list, and delete it (pressing "delete"). File disappears, and XnView insists on refreshing the entire list - forcing me to find back the point in the list I was at.
Strange, i have not this bug. Which OS?
notnoisy
Post by notnoisy »
Windows Server 2003
On Windows XP this works fine.
But:
Perhaps this problem is related to Image select in browser. In the options dialog, category 'Browser->File list', frame 'Items shown in other mode', I've unchecked 'All files'. And voilà, the problem described by you (notnoisy) appears.
@Notnoisy: Could you please check, whether this is unchecked on your box, too? If so, please check the option, try again, and let us know about the result, here.
notnoisy
Post by notnoisy »
helmut wrote:On Windows XP this works fine.
But:
Bingo! I had it unchecked, for a good reason, but checking it solved the problem.
Good thinking, helmut :D
