.ogm files support
ASLÑK
Problem with .ogm files.
Post by ASLÑK »
<Moderator's note: This topic has been split from another topic>
I have problems with .ogm files. Xnwiew can't reproduce this kind of file extension?. when I try to reproduce this files, the program stop working. I don't know if is my computer or is the program.
BUDA20
adding a new directshow extension
Post by BUDA20 »
adding a new directshow extension for thumbinals in windows (and then in xnview)
Make a reg file like this, and add it to your registry (simple doible click)
(I using gomplayer so you see gomplayer file and so on...)
example OGM.REG
Windows Registry Editor Version 5.00
[HKEY_CLASSES_ROOT\.ogm]
@="GomPlayer.ogm"
"PerceivedType"="video"
"Content Type"="video/ogm"
"GomPlayer_bak"="ogmfile"
[HKEY_CLASSES_ROOT\.ogm\ShellEx]
[HKEY_CLASSES_ROOT\.ogm\ShellEx\{BB2E617C-0920-11d1-9A0B-00C04FC2D6C1}]
@="{c5a40261-cd64-4ccf-84cb-c394da41d590}"
You can set any extension, when you add this to the registry press F5 or rebuild thumbnails.
Regars from forometropolis.com.ar Argentina.
