paste image to file in browser
candela
Post by candela »
I'd like to be able to paste an image from the clipboard directly to a file in the browser. Right now, you need to import from clipboard, choose save as, browse to the directory and save.
It would be much easier when you could paste in the browser and directly save the image in the folder you are currently in.
Re: paste image to file in browser
candela wrote:I'd like to be able to paste an image from the clipboard directly to a file in the browser. Right now, you need to import from clipboard, choose save as, browse to the directory and save.
Like "Aquire into", a 'Capture into"?
candela
Post by candela »
Yes, something like that but with the save directory set by default to the current directory in the browser.
