Create Webpage
voyager101
Create Webpage
Post by voyager101 »
When I use Create Webpage in the menu, is there any way to get Xnview to put the A href="http://____.____.home.ne.jp/r____h/images line in automatically?
Thanks
Re: Create Webpage
voyager101 wrote:When I use Create Webpage in the menu, is there any way to get Xnview to put the A href="http://____.____.home.ne.jp/r____h/images line in automatically?
Thanks
Could you explain me more, please?
voyager101
a href=original IMG_0002.JPG img src =thumb / t_IMG_0002.jpg alt= IMG_0002.JPG <div></div>
</td>
What i am asking is there a way for XNView to put in the url for my webpage instead of putting original / img_ and img src = while it is creating the webpage?
voyager101 wrote:a href=original IMG_0002.JPG img src =thumb / t_IMG_0002.jpg alt= IMG_0002.JPG <div></div>
</td>
Currently no
voyager101
Thanks for the response.
Drahken
Post by Drahken »
It should be possible for you to hack it in by going into the web templates folder, selecting the appropriate template, and inserting the URL of your page in the right place. ie, Change:
<a href="#FRAME_PAGE#"><img src="#THUMB_LINK#" alt="#FILENAME#" width="#THUMB_WIDTH#" height="#THUMB_HEIGHT#"></a>
to:
<a href="http://site.com/subdomain/#FRAME_PAGE#"><img src="http://site.com/subdomain/#THUMB_LINK#" alt="#FILENAME#" width="#THUMB_WIDTH#" height="#THUMB_HEIGHT#"></a>
