Thumbnails size does'not work at more then 192px
hausl78
Post by hausl78 »
Hi!
If i try to define the size of the thumbnails higher then 192 px, only the frame (= the reserved white) around the thumb get's bigger but NOT THE THUMB (the picture) itself!
How can i do this, i want the Thumbs to habe a size about 250 or 300 px.
The size of the orig pics are 1280 x 960 px
Thanks a lot!!
Juergen Haeusler
Austria
Hello hausl78!
Could you please post a screenshot of your thumbnail settings:
Options » Browser » Thumbnail » Appearance
[ Zoom ]
Cute baby, BTW :)
ckv
Post by ckv »
Hi.
My guess would be that you have the "Use Embedded thumbnail" option on. Go to "Options / Browser / Thumbnail" and uncheck the "Use Embedded thumbnail", if it is checked.
If that didn't help, it's probably a cache problem. In this case you can try to disable the cache in "Options / Browser / Cache" and see if it works. If it does, I recommend that you delete the whole cache.
hausl78
Thumbnails ... THE SOLUTION
Post by hausl78 »
Hi!
Thanks for your help, i tried first to disable the "embedded..." and now it works!!
Thanks
Juergen
