Hi, how can I save and export (i.e. from the hard disk to a CD-R) images with the connected database info that I have added (descriptions, etc...).
I hope my question is clear enough. Thank you in advance!
Paolo
Save and export database info
Re: save and export database info
Not yet possible, but i'll add such feature.zan1964 wrote:Hi, how can I save and export (i.e. from the hard disk to a CD-R) images with the connected database info that I have added (descriptions, etc...).
zan1964
Pierre, thank you very much for your reply.
It would be nice and useful if XnView will recognize database files made by Acdsee
Bye,
Paolo
Bye,
Paolo
Do you know the format?zan1964 wrote:Pierre, thank you very much for your reply.
I wonder whether it is legal to read ACDSee database files directly. One should read the licence agreement of ACDSee carefully and/or contact ACDSystems.zan1964 wrote:Pierre, thank you very much for your reply.
It would be nice and useful if XnView will recognize database files made by Acdsee![]()
zan1964
ACDSee stores the data in a XML file. I don't know if it is legal or not for a different software to use said data. If yes, it would be nice and useful.xnview wrote:Do you know the format?zan1964 wrote:Pierre, thank you very much for your reply.
Paolo
In ACDsee 6, i have only found DB files, no XML files.zan1964 wrote:ACDSee stores the data in a XML file. I don't know if it is legal or not for a different software to use said data. If yes, it would be nice and useful.
