Bug Report [Garbage when scrolling thumbnails]
Discussions on XnView for PocketPC
redkin
Post by redkin »
Soft: XNView Pocket 1.35
HPC: HP iPaq hx4700 (firmware:1.10.08 ENG)
OS: Windows Mobile 2003 SE
BUG: Garbage when scrolling thumbnails
Description:
When I use thumbnails view, and there are many images in the folder, when I scroll thumbnails window by tapping scrollbar, thumbnails in the rightmost column have garbage (they look like shifted from the right place).
When I click on thumbnail after that it's redrawn OK.
When I scroll by hardware buttons or when scrolling by page everything is OK too.
Looks like the bug is when "smooth scrolling" is used instead of redrawing of all window.
Maybe it's a problem of my video card ?
Re: Bug Report [Garbage when scrolling thumbnails]
redkin wrote:Soft: XNView Pocket 1.35
Description:
Is it possible to make a screenshot?
Screenshot attached
Post by Guest »
screenshot
Press orange link on the right to download screenshot.
Also I should note that bug only appears if I drag window splitter up or down. When it's in default half-screen position, everything is ok.
i see this bug too
Post by Guest »
i have same PPC - hx4700, and experience same problem - garbage in rightmost row (and once i had garbage also in middle row), i saw this bug on OS 2003SE and on OS WM5 too.
Re: Screenshot attached
Anonymous wrote:screenshot
And the problem is only on the right row??
redkin
Post by redkin »
In most cases it's only the rightmost column, but there were some times (once or twice) when the second on the right column was spoiled too.
redkin wrote:In most cases it's only the rightmost column, but there were some times (once or twice) when the second on the right column was spoiled too.
And you have this problem only with a lot of pictures??
