Faxes are displayed stretched. The format is always horizontal instead of vertical.
The problem seems similar to this:
http://newsgroup.xnview.com/viewtopic.php?t=6185
We use XNView 1.82.4 on various OS.
Any idea?
Gerd
Bug: Tiffs (Faxes) are displayed stretched
Re: Bug: Tiffs (Faxes) are displayed stretched
Do you have option/view/Adjust zoom if X/YDPI...?GKR wrote:Faxes are displayed stretched. The format is always horizontal instead of vertical.
Any idea?
GKR
Now it works!
Now it works.
Merci beaucoup, Pierre!
Kind Regards
Gerd
Kind Regards
Gerd
