If you look into the field "title" in document properties in adobe reader or foxitreader, it shows the path without backslashes and some other characters.
e.g. it shows that:
C:okumente und EinstellungendminesktopMG_2346.pdf
But it should show:
C:\Dokumente und Einstellungen\admin\Desktop\vierpole_uebersicht.pdf
By the way, it would better to show only the filename as title. I think that's more secure
wrong title in exported pdf file - some chars missing
andreasm82
My private (german) page www.energie-bewusstsein.de
Re: wrong title in exported pdf file - some chars missing
Ok, i'll checkandreasm82 wrote:If you look into the field "title" in document properties in adobe reader or foxitreader, it shows the path without backslashes and some other characters.
e.g. it shows that:
But it should show:
andreasm82
If you need further information or a sample file, just say it
