Convert to .fax
Convert to .fax
Post by Guest »
I tried to convert a file to .fax, but the wrote a message that explain that option is not implemented... Is possible to convert to .fax?
Is possible to convert to a black and white file ( not gray scale, only black and white )?
Post by Guest »
the program wote a message...
Re: Convert to .fax
Anonymous wrote:I tried to convert a file to .fax, but the wrote a message that explain that option is not implemented... Is possible to convert to .fax?
Which format of fax?
David_T
Post by David_T »
file must be binary color before convert to fax G4
