File format identification ?
FredLynx
Post by FredLynx »
I found a strange file forma. I explain, i have image file with a .bmp extention but when i try to open them it's impossible.
When i look in hex format the haeder start with RL in hex 52 4C 01 00 or 52 4C 00 00
Somme body can help me on this type of file ? Il sure that it's a bmp file tranform with some thing but what ???
Thanks for your answer.
Fredlynx
Re: File format identification ?
FredLynx wrote:Hi,
Fredlynx
Could you send me a sample? Which software use it?
Post by Guest »
Je penche pour une compression de type Zlib peut être !?
