Renaming and all pictures are gone
guest
Post by guest »
hello,
i normally work every day with xnview, but now ive tried to rename 300 pictures of my holiday( i have no copy) and now they are all gone exept one. is there a chance to find the pictures?
thanks a lot
regards gerd
Re: Renaming and all pictures are gone
guest wrote:... ive tried to rename 300 pictures of my holiday( i have no copy) and now they are all gone except one. is there a chance to find the pictures?
This sounds pretty bad and I hope that you can find your images, again.
Which version of XnView did you use?
To find your images, you should use the search of MS Explorer or XnView. When renaming the images, XnView keeps the timestamp of the images by default. So a search with MS Explorer for files that have been changed/created in a specific time frame is a good idea. When searching, you might want to search the whole hard disk, unless you can remember the target dir.
Cross fingers that you find your pics!
Helmut
