Optional settings for writing postscript?
hawkse
Post by hawkse »
I am trying to batch print a large number of tiff (g4) files to a postscript printer. I do this by calling nconvert like this:
nconvert.exe -quiet -out ps -o \\computer\spool c:\Temp\faximage.tif
The job spools and reaches the printer but doesn't print since the printer still shows the message "waiting for data". If I then press the "OK" button on the printer, the image is printed OK.
I have also tried this by printing to a local printer but with the same result.
Trying to convert and print using pcl format instead also gives the same result.
If I convert the image into a postscript file, I can open the file in GSView and it looks good there.
I then tried to copy the postscript file produced by nconvert to the printer:
copy faximage.ps \\computer\spool
This also gave the same result (have to press "OK" button on printer to get the image printed).
If I take another postscript file (produced from a pdf by pdftops.exe from xpdf) and copy it to the print spool it will print directly without waiting for more data.
This leads me to believe that this must have something to do with the postscript format produced nconvert . Is it possible to somehow alter the postscript written by nconvert (ie, level 1,2 or 3)?
Re: Optional settings for writing postscript?
hawkse wrote:This leads me to believe that this must have something to do with the postscript format produced nconvert . Is it possible to somehow alter the postscript written by nconvert (ie, level 1,2 or 3)?
Strange, could you send a ps sample?
hawkse
Post by hawkse »
The sample is in the mail. I found this page suggesting adding a "form feed" at the end of the job on the Microsoft site:
http://support.microsoft.com/kb/q132460/
I tried setting the queue to RAW Append and RAW Auto as suggested there but it didn't make any difference.
Which mail? at xnview.com??
hawkse
Post by hawkse »
xnview wrote:
hawkse wrote:
xnview wrote: Strange, could you send a ps sample?
The one listed for your MSN account (pierre g wanadoo fr) here.
hawkse wrote:
xnview wrote:
hawkse wrote: The sample is in the mail.
No, please [email protected] (remove -nospam)
