Recursive renaming (renaming files in subfolders)
klinge
Post by klinge »
I find myself using the rename functionality in XnView alot because it's one of the best and most flexible renamers for digital images I have found.
In my opinon it only lacks one feature: the ability to rename all files from a given folder including all its subfolders. Wouldn't that be great! Or does anyone have a different opinion?
Regards,
klinge
Re: Recursive renaming (renaming files in subfolders)
klinge wrote:I find myself using the rename functionality in XnView alot because it's one of the best and most flexible renamers for digital images I have found.
But you can rename files in subfolders too...
